Looking for high resolution monitor for under $400
im looking for a high resolution 27" or bigger gaming monitor under $400.i like higher resolution over high refresh rate.
and no bigger than 30" as my desk wont fit anything bigger.
i like rpgs like the witcher and dragon age.
i have a Gigabyte GTX 970 G1 Gaming GPU
can you help me?
I assume by high resolution you mean you want a 1440p monitor right?
You could get an Asus PB278Q for your price range, it's probably the best one tbh:
http://www.amazon.com/dp/B009C3M7H0/?tag=pcpapi-20
That's 27", 2560x1440, IPS Panel (PLS)
You'll get amazing colours and viewing angles from that along with a high res! (Although your 970's may start to have issues powering some games at 1440p, just turn down/off AA and you should be okay in most games, and a few other settings if needed.)
If you wanted something cheaper, maybe the
Acer K272HUL (http://www.amazon.com/Acer-K272HUL-bmiidp-27-inch-Widescreen/dp/B00JB6HCIC)
It's a good price, and same base features as the Asus. Either way I would recommend an IPS Panel at your price point to get the best possible colours.
