Radiator fans [Q]
Solved by C0LL0SS0S,
To be quite honest, it depends on the Radiator, if the FPI is pretty high you need static pressure regardless, otherwise I guess both are fine. But always prefer static pressure fans since they also create more suction
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking13 -
apoyusiken ·
Posted in PC Gaming1 -
6
MattJames595 ·
