390 or 970 HELP ASAP!
Knaj
390 has more vram and powerfull core and CHEAPER
watch this video
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
Well.... Your rig could handle either cards. And the 2 cards are neck and neck in performance. So go with whichever card you like honestly...
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
oh my god.... I swear one more question about these two cards and I'll commit suicide, do your research before you post, there are a lot of youtube videos
and so many posts on the internet about this question...
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
Personally a 970 fan, but it comes down to the buyer :/
I'm buying my new pc today!! And I've heard a lot about the 390 over the 970, so should I get the 390 or the 970 for this rig?? http://pcpartpicker.com/p/jNhCWZ
Well.... Your rig could handle either cards. So go with whichever card you like honestly...
the cards are similar but the r9 390 has more vram for lower price and perform the same so more vram cheaper what more ?
You're going to see a very small difference between the two, pick what you like looks nice, and if either is on sale!
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
The r9 390 can't even use 8gb of vram
So 970 for 1080p
and 390 for 1440p and above
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
The 970 isn't as power hungry as the 390.
yeah oke but the new frtc may help with that and also i can't argue with that but who cares about power consumption at no that big of a difference
So 970 for 1080p
Those 8 gigs were made for crossfire, but good luck loading heavy texture packs with the 3.5gb meme card.
The 390 is a better all rounder for 1080p, even.
The 970 has full 4GBs not 3.5GBs....
Yeah, but good luck using the last .5GBs.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
This is what the forum is here for. We answer people's questions, not tell them to look it up themselves.
@OP The 390 is better in pretty much all cases. Even at 1080p it's either equal or beating the 970.
 but .5 that you DONT want to use.
3,5 fast and 0,5 slow vram vs 8gb fast vram
Give this user's post some likes.
these 0.5GBs will slow down the card ON SOME INSTANCES NOT, every time that they are used.
I agree, It comes down to this:
390 does have more vram
Both are very similar in price
I prefer 970 so i can have stuff like shadowplay. I think it works great for all desktop recording.
I'm also just a general fan of GeForce...I have a 760 in my pc right now.
So I know you asked for suggestions, but pick whatever the hell you want.
In the end, the people typing in this forum won't be the one using a card. It's your system :/
R9 390. More VRAM, Neck-To-Neck Performance, Most likely cheaper as well.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
