At first I thought it was a way to keep the power stable ... But now I read that you don't need a PSU when you have a UPS , is this true ? If so , what is a USP ?
... Life is a game and the checkpoints are your birthday , you will face challenges where you may not get rewarded afterwords but those are the challenges that help you improve yourself . Always live for tomorrow because you may never know when your game will be over ... I'm totally not going insane in anyway , shape or form ... I just have broken English and an open mind ...
https://linustechtips.com/topic/407895-what-is-a-ups/
UPS = Uninterruptible power supply
It's a PSU that provides backup power when the main power fails so you can backup your data before shutting down your computer.Also, it can protect it from voltage changes.
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495520
Uninterruptible Power Supply...
Think of it as backup power so you can safely shutdown your PC in the case of a power failure...
And you need a PSU for that... AVR is optional though...
a USP is a brand model of firearm by Hecker&Koch... (kudos to @ShadowCaptain for correcting)
and UPS can also be that shipping service...
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495525
The primary role of any UPS is to provide short-term power when the input power source fails. However, most UPS units are also capable in varying degrees of correcting common utility power problems:
  • Voltage spike or sustained overvoltage
  • Momentary or sustained reduction in input voltage
  • Noise, defined as a high frequency transient or oscillation, usually injected into the line by nearby equipment
  • Instability of the mains frequency
  • Harmonic distortion: defined as a departure from the ideal sinusoidal waveform expected on the line
- Wikipedia
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495527
a USP is a brand of firearm...
Actually a USP is a model, the brand is Heckler and Koch
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495542
thanks for correcting..
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495548
basicly, a UPS is a battery bank but instead of USB ports, you have wall power sockets.
(very crude way of putting it, but yeah, thats kinda what it does)
a UPS provided the following advantages:
- overcurrent protection
- battery backup on power outage
- protection against bad voltages on mains (my router used to do really weird stuff because voltages in my area were high, solved with a UPS)
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495554
Not needing a PSU when you have a UPS is news to me. Depending on how fancy your UPS is,
it can do a few things:
- prevent power surges from damaging your equipment
- provide backup power in case of the power grid going down via batteries
- when the batteries run low, send a signal to the machines hooked up to it that they should gracefully power down
- when you have power generators as a more long-term backup, the batteries can provide an emergency buffer until the generators have powered up
(say, in a data center)
There might be more, but those are the most important things which come to mind off the top of my head.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495558
UPS, SPU, PSU, USP.. WUUT?  :wacko:  :blink:
Deal with it  B) sorry ...
So where does the UPS get power from ? The wall or the PSU ?
- Wikipedia
Ah ... So it's like a backup generator that immediately kicks in when the power is cut ...
So if the power is cut , you use your UPS , but what if the power is cut briefly ? I can power everything back once power is resotred without the power surge , right ?
How many power divider can a UPS hold ? ( I don;t know what those are called ... )
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495562
Somebody has to :D
yeah in laymans terms sure, its a big battery that powers the computer if power is lost, cheap ones generally only last a few minutes giving you time to save your documents and safely shut down
more expensive ones give more time and more wattage
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495563
Yeah kinda, it's more of a battery.
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495577
The UPS has a battery inside... It charges up when there is power going through the AC input...
http://computer.howstuffworks.com/question28.htm
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495584
No likes for you ...
I edited my huge reply up above , could you answer the question above as well ?
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495622
Dont forget about AVRs also. Those that do correct voltage spike and droops without having a battery. Technically has one but not for powering up.
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495634
1. So where does the UPS get power from ? The wall or the PSU ?
2. So if the power is cut , you use your UPS , but what if the power is cut briefly ? I can power everything back once power is resotred without the power surge , right ?
3. How many power divider can a UPS hold ? ( I don;t know what those are called ... )
1. The UPS gets power from the wall, you plug your PSU to the UPS.
2. I don't get that, can you please rephrase that?
3. It depends
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495645
The UPS pulls power from the wall to charge up the battery...
setup goes like: Wall -> UPS -> PC and other devices
in the case that the power is cut from the wall, the UPS's backup power kicks in and keeps the PC running for a few more minutes...
the capacity of the UPS is dependent on its rating... you should always put a huge margin between the UPS capacity and the load that you're connecting to it to give the devices more time to be safely shut down...
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495658
3. It depends
What I'm trying to say is : If the power is out for about 3 minutes , then it turns back on again , it should be able to continue running right without surges right ?
So the Capacity of the batteries is measured in Watts right ?
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495696
Yes.
UPS capacity is in Watts but battery capacity is in mAh... you can estimate the amout of time between power failure and shutdown by dividing the battery capacity by max wattage of the load...
most UPSs promise at least 5 minutes of extra power at maximum rated capacity... just avoid the off-brand ones at all costs...
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495746
Yes.
Usually VA but it is easily converted into Watts.
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495771
Yes.
What brand is most trusted for UPSs ?
Yes.
Ah ... Okay then , thank you . I'll ask how to convert that in the future ...
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495800
Our university uses APC... and so far it hasn't failed us...
as for the estimate...
multiply the battery capacity by the voltage (120V or 240V, depending on region) to get the amount of usable power you have in Watt-hours,,,
divide that value by the load wattage to get the amount of time...
or at least that's how I calculate the amount of spare time in my power banks...
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5495903
Highly recommend APC brand UPS's they've work great for me over the years. For the wattages of your UPS just make sure it is larger than the maximum draw from your system when fully loaded it will ensure that the UPS has enough power to run your system when battery backup kicks in and not trip the over current protection.
https://linustechtips.com/topic/407895-what-is-a-ups/#findComment-5499729
