Logitech G300s is loosing connection
.stormer
Hello
I have a problem with my mouse (Logitech G300s) (1 month old), the mouse is always disconnecting itself and connecting again. I tried to update the driver but it didnt worked, also i tried to plug it in another USB port, i tried to plug it into a USB 3.0 Port but still it dosent want to work. It is really annyoing in CSGO especially.
Thanks in advance
Its probably logitechs god awful drivers for their terrible products.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
Hello
Thanks in advance
You probably have a defective cable on your mouse, my Cooler Master keyboard did the same thing, luckily the cable is removable and I had them send me a new one fix the issue.
Case - Fractal Design Arc Mini R2 : Mobo - Asus Maximus VI Gene : PSU - Corsair AX760 : CPU - Intel i7 4790k w/ EK-Supremacy EVO Copper/Acetal Water Block  : Memory - Corsair Vengence Pro 24gb 1600mhz : GPU - Evga GTX 780 Ti Classified w/ EK-FC780 GTX Classy - Acetal+Nickel Water Block : Storage - Samsung 840 Evo 250gb & 850 Evo 1tb SSDs, 2x 6TB External HDDs : Fans - 5x Noctua NF-F12 & 1x NF-S12A : Display - 24in Benq XL2420TE : Rads - Darkside LPX360 & LP240 : Pump/Res - EK-XRES 140 D5 Vario Pump
