Cheap whole system cooling - 500$ to 1200$
Thank you everyone who has responded so far, as I wrote I will be upgrading to a 980ti or higher in the coming year or two, so that should be kept in mind, though if things happen and I have to use 970's for that period, I will buy a second.
Hello, I am presenting the question because I might be going to a fully water cooled system in the coming year or 2 and am looking at options to make this work for a good price, this is also to help anyone else out in a situation like this where they might be upgrading or are upgrading currently.
The budget for this would be 500$ for the low end, 800$ for the high end, and 1200$ for the dream high end. This thread can mainly be discussion but things like PcPartPicker being used would be awesome, to give some examples of what users on this thread might mean.
The parts involved, aside from the water cooling would be, a Noctis 450 (my own case), GTX 970, or 980Ti.
The loop has to cool the cpu, cool the gpu and dissipate the heat, please keep in mind I am not an experienced user with water cooling and so I don't know if anything I am saying is odd sounding or wrong.
For a starter water cooling kit, Just get a good cpu block, gpu block, double/triple rad (or whatever you can fit), some regular water cooling tube, regular barb fittings, and a good pump/res. Keep it simple you can always upgrade down the road if you want to. you can probably get all that for $400-500 USD.
For water blocks EKWB is always a good choice. Rads EKWB, Alphacool, Darkside are good, Pump D5 is amazing.
