http://imgur.com/2xwPpEg,uNsoxbi#1
These the the plugs. Any idea why they won't work?
I'm assuming the wires don't match up, but there are only 4 wires; two to the power button, two to the LED.
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/406030-power-button-plug-not-fitting/
That's looks more like an internal USB plug in the 2nd picture. The power switch etc will be 2 wires, and there should be 3 or 4 sets.
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
Would it be a 2x3 plug with one of the middle ones missing?
are you using a proprietary case?
thats the only place i ever saw a case use a block style plug for buttons/leds
What do you mean by proprietary?
The wires from the power button lead directly to that plug.
Insert the separate wires instead of using the hub.
How do I do that?
I think that is a USB internal connector, The LED's, power switch, reset switch come separately from each other
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
Then why does the wire lead directly to the power button?
What case are you using? If its a pre built, then you need to redo the front panel connections
Its a Lenovo Erazer x315 case... In other words I need a new power button?
like a case from HP, dell or acer thats for one of their prebuilt machines.
Yeah it's a lenovo case...
I'm assuming I need to get a new power button. Any places that would have it locally? Like Best Buy or Staples?
if you can figure out what holes in the connector are hooked up to what, you can just take the individual cables and hook them up. (that type of connector disassembles rather easy)
Thanks; I'll have my friend who lives a block away help me now. Shouldn't be too hard (hopefully)
But just in case; could anyone link me a decent one thats under $30? Thanks!
