fellow razer blade users what temps do you get
Chibify
I don't know but  my razor blade stays pretty cool when I shave..... :ph34r:
/s   lol sorry couldn't help myself.
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
I don't have one, but I will leave the suggestion to check in with the forum at notebookreview.com if you can't find a good user group here.
There, you'll be able to find others that use the same laptop for sure, and it's a great place to find other owners to get specific help on any laptop.
muh specs
Gaming and HTPC (reparations)- ASUS 1080, MSI X99A SLI Plus, 5820k- 4.5GHz @ 1.25v, asetek based 360mm AIO, RM 1000x, 16GB memory, 750D with front USB 2.0 replaced with 3.0  ports, 2 250GB 850 EVOs in Raid 0 (why not, only has games on it), some hard drives
Screens- Acer preditor XB241H (1080p, 144Hz Gsync), LG 1080p ultrawide, (all mounted) directly wired to TV in other room
Stuff- k70 with reds, steel series rival, g13, full desk covering mouse mat
All parts black
Workstation(desk)- 3770k, 970 reference, 16GB of some crucial memory, a motherboard of some kind I don't remember, Micomsoft SC-512N1-L/DVI, CM Storm Trooper (It's got a handle, can you handle that?), 240mm Asetek based AIO, Crucial M550 256GB (upgrade soon), some hard drives, disc drives, and hot swap bays
Screens- 3  ASUS VN248H-P IPS 1080p screens mounted on a stand, some old tv on the wall above it.
Stuff- Epicgear defiant (solderless swappable switches), g600, moutned mic and other stuff.
Laptop docking area- 2 1440p korean monitors mounted, one AHVA matte, one samsung PLS gloss (very annoying, yes). Trashy Razer blackwidow chroma...I mean like the J key doesn't click anymore. I got a model M i use on it to, but its time for a new keyboard. Some edgy Utechsmart mouse similar to g600. Hooked to laptop dock for both of my dell precision laptops. (not only docking area)
Shelf- i7-2600 non-k (has vt-d), 380t, some ASUS sandy itx board, intel quad nic. Currently hosts shared files, setting up as pfsense box in VM. Also acts as spare gaming PC with a 580 or whatever someone brings. Hooked into laptop dock area via usb switch
Well I'll tell you mine, under load I get 85-86C on the CPU and 76-77 on the GPU and at idle I get 40C on the CPU and 33 on the GPU but this is with an undervolted CPU.
[ Rig: CPU: 4930K, GPU: EVGA 780TI SC x2, RAM: 32GB Corsair Vengeance 1600MHz, Mobo: ASUS P9 X79 LE, Storage: 120GB Samsung EVO + 2TB Seagate Barracuda, PSU: Corsair RM1000 ]
