As of recently I've noticed my SSD's been quite ishy when booting up, boot is about 3 seconds longer than before and I benchmarked it with AS SSD, Screenshot here:lqjx0vi.png
Can anyone help?
Cpu: i5-2500k @4.8Ghz, MB: Asus Maximus V Formula, CPU cooler: Be quiet! Dark rock pro 2, GPU: Evga Gtx660 FTW@1.24ghz. Ram: Corsair Vengeance 8GB 1866Mhz, PSU: Be quiet! 730w Semi modular, SSD: Corsair force 3 240Gb, HDD: WD Green 1TB, Case: Nzxt H2 with 4 Corsair SP120's, Win7
https://linustechtips.com/topic/40461-is-there-a-problem-with-my-ssd/
Is it getting close to full?
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
Still 159 - 162 GB free.
Still 159 - 162 GB free.[/quote
Wouldn't be that then...
Could you try a fresh install??
ame="Ddm5" post="523604" timestamp="1375046066"]Still 159 - 162 GB free.[/quote
No chance, I don't fancy installing everything once again, SSD's on the right Sata port aswell with trim enabled.
Have you got an optical drive? if so have you left a disc in?  My pc takes about 5 sec. longer to boot if there is a disc in the drive as the bios searches it for a boot sector.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
Try uninstalling Intel Rapid Storage Technology ("iaStor" in SA SSD signifies you're using it) in Add/Remove Programs. The Intel driver often conflicts with some SSD slowing them, it's better to use the drivers for your particular SSD.
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
That still shouldn't be giving such low results in crystal disk..
true, I was only thinking about the slow boot time because I don't know of hand what the average read/write speeds are for the force 3.
Is this drive one of the effected force 3's that corsair issued notifications on?
http://forum.corsair.com/v3/showthread.php?t=95688
