Car Help!
Guest Philosophy
Some cars have a camshaft position sensor. they just tell you if the camshaft is running. it might have gone bad.
https://linustechtips.com/topic/402699-car-help/#findComment-5429694
Okay.
Or it could be the wiring, go get that checked out @
I done some reading and it seems the alternator is a SUPER common cause of this light. I can get an alternator for $40 bucks and it would be an easy cheap fix if that is all it was.
https://linustechtips.com/topic/402699-car-help/#findComment-5429765
I would still get it checked out to see if it might be any of the wiring for the sensor or the sensor itself before putting any money in to a repair.
https://linustechtips.com/topic/402699-car-help/#findComment-5429783
See it would be 195+ dollars to do that, that is why I am hesitant. Where is I can fix it for $40, then I have saved myself nearly 200 bucks.
https://linustechtips.com/topic/402699-car-help/#findComment-5429793
Nah? All you have to do is look if any of the wires are damaged or grounding on anything. Plus if the alternator is fine you're down $40 and still have something else to replace.
https://linustechtips.com/topic/402699-car-help/#findComment-5429798
I am troubleshooting as we speak. It is nothing major. I am not misfiring or backfiring. I know it is not a cam shaft or fuel injection problem. So it is:  missing ground, an alternator, bad computer or bad sensor.
The light comes on about every 50 miles, if I reset it, it will come on in about 150 miles.
https://linustechtips.com/topic/402699-car-help/#findComment-5429883
Update me on anything you find out?
https://linustechtips.com/topic/402699-car-help/#findComment-5429905
It has to be the computer. I drove it to try and diagnose it and boom the check engine light goes away. So I drive it 50 more miles never comes back on.
No not really... intermittent issues can turn off the light because it doesn't find a fault in another monitor cycle. Those codes are still stored as a history code.
If I had to guess, probably sensor. Heat can cause sensors like that to work fine until they get a certain temperature. Alternator is possible... hard to check without a multimeter but you can just turn on everything electrical (blower motor max, rear defroster, wipers, headlights) and see if it comes back on or even stumbles. I was actually working on an 06 F-150 that had a cam sensor code and their diagnostic tree said to test the alternator for leaking AC voltage.
5800X3D / ASUS X570 Dark Hero / 64GB 3600mhz / EVGA RTX 3090ti FTW3 Ultra / Dell S3422DWG / Razer Deathstalker v2 / Razer Basilisk v3 Pro / Sennheiser HD 600
2021 Razer Blade 14 3070 / iPhone 15 Pro Max
https://linustechtips.com/topic/402699-car-help/#findComment-5430298
What makes me think it is the computer is that it is spitting a different unrelated code each time. I have gotten a Transmission code, a crankshaft code, a "void" code etc. None of which are having any issues. I looked and nothing is mechanically wrong with the car
https://linustechtips.com/topic/402699-car-help/#findComment-5430331
Well you only stated you have a cam sensor code originally...
https://linustechtips.com/topic/402699-car-help/#findComment-5430405
