i7 4790k stock cooler no OC
Z97 gigabyte gaming 3
Hyperx Fury SSD 240GB
Seagate 2TB HDD
EVGA 780Ti K|NGP|N 1249 Core 1950 Memory
Currently sitting on a Tt TR2 700W Psu
Current issue , if I take the voltage above 1.187 on precision it will run for like 5 min and shutdonw without getting to high temps on the GPU or CPU.
Edit: Please leave recommendations on good quality psu's
https://linustechtips.com/topic/400970-how-many-watts-i-need/
@WereCat i made a 600W tr2 Tt blow up with 1.171v on the card so.. i dont think 500w is enough or Tt psu's are not that good (Tr2 models are 80+ bronze )
Of course. If you have crappy PSU it doesent matter how much wattage you got.
500W is actualy enough even if you OC a lot.
Just because PSU is Bronze, Silver, Gold, Platinum doesent mean it is good.. that is just efficiency rating and it doesent say anything about quality of the components. It is actualy fairly easy to make really bad but very efficient PSU.
https://linustechtips.com/topic/400970-how-many-watts-i-need/#findComment-5405484
TR2s are absolutely awful.
@WereCat any recommendations on a good psu?
Take a look at the EVGA 550GS or 750B2.
"Rawr XD"
https://linustechtips.com/topic/400970-how-many-watts-i-need/#findComment-5406812
