I found dis on ebay, and was wondering if it is worth it:
http://www.ebay.com/itm/12000mah-Dual-USB-5V-1A-2-1A-Power-Bank-18650-Battery-Charger-DIY-Box-For-Phone-/371319771890?pt=LH_DefaultDomain_0&var=&hash=item56746212f2
It takes the cells that come from laptop batteries which I have TONS of just laying around from old laptops.
Anyone have experience with anything like this? Is it going to catch on fire when I try to use it. xD?
Is it bad that my dream setup only costs a few thousand not counting the obutto?
CPU: FX-8320
Motherboard: asrock 970Pro3 r2.0
Memory: Team Zeus Blue 8GB DDR3-1600 Memory
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card
Case: Deepcool TESSERACT BF ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Certified ATX Power Supply
SSD: MX100 128GB
HDD: WD 2TB black edition
https://linustechtips.com/topic/399819-chinese-battery-pack/
TBH batterypacks are not that expensive in Europe/US, I would not risk it, but the price is pretty dope, payed 20€ for 13000mh
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5389359
i wouldnt touch that with a 10 foot pole.
I picked up one of these. Its the best, cheapest 10,000 mAh chargers on the market https://oneplus.net/oneplus-power-bank
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5389364
If you have experience with this stuff, go ahead. I have made a 500w/h battery pack from 18650 cells before. As long as china didnt put any of their batteries in it, it should be fine.
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5389410
Explain why though. the pricing makes sense. It is just the electronics, without the $20 of battery cells.
Its not about the price of a batterypack, I want use up at least some of the 5gallon bucket of 18650 cells I have in my attic, instead of just throwing them away.
CPU: FX-8320
SSD: MX100 128GB
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5389412
Yea, I took a small electronics class last year, so I feel comfortable with it. Just wanted to know if there something I was missing, maybe someone had experience of one exploding in there face.
CPU: FX-8320
SSD: MX100 128GB
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5389423
Call me a pussy but I would not reuse old Lapotop batteries for your battery pack
EDIT: You know what you are doing, go for it
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5389429
Here you go. Here is my massive battery pack:
haha, what do you use that for?
CPU: FX-8320
SSD: MX100 128GB
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5389636
electric bike
ah ok.
if you can find them, thinkpad g40/g41 packs have 3 sets of four batteries and make building a pack really easy.
Yea, I have a few toshiba batteries that have 9.
CPU: FX-8320
SSD: MX100 128GB
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5391408
After having experience with off brand battery packs, no, it's not worth it. I can tell you right now (again, from experience) that the batteries will be shotty, the USB ports will break, and everything will be shotty.
I personally have an Anker power bank now and love it. It's worth the extra money, trust me.
COMIC SANS
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5391598
How did you go about building it? Like, what all would I need? Because I have spare batteries lying around.
COMIC SANS
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5391605
Because of the tabs spanning the batteries in parallel, I just soldered some solid core copper wire as a jumper from each cell pack.
https://linustechtips.com/topic/399819-chinese-battery-pack/#findComment-5392778
