Speed/Performance Difference Between 32-Bit and 64-Bit OS?
Go to solution Solved by 007agentHP,
there is no performance gain. the 64 bit can access more ram. 32 bit is limited to 4 gb. 64 is 16 billion gb
Hi all, just wanted to know if there is a speed difference and by how much there is between running a 32-Bit OS and a 64-Bit OS (Windows 7)
Say the CPU is an Intel Core 2 Duo E8400
BRRRT!
PC
  • ASUS TUF GAMING B550M Plus
  • Ryzen 5 5600X undervolted
  • Gigabyte VISION OC RTX 3070 undervolted
  • 32GB Teamgroup Dark Alpha 3600 MHz CL18
  • Corsair TX750M
  • Fractal Design Meshify C Mini
Sim Equipment
  • Logitech Extreme 3D Pro & Thrustmaster TWCS Throttle
  • Logitech G27 with pedals and H-shifter
  • TrackIR 4
32-bit software will run the same.
64-bit software will only run on one, so there's no comparison here.
Really, it's about software support more than speed. But if you have a choice between the two there's literally no reason to going with a 32-bit, you only limit yourself for no reason.
I'm not sure, but i know there is a memory cap for x86 bit at 3-4 gb, but x64 is basically unlimited.
Happy to help with any tech problems. Windows 10 installing guide here.
----i5 4570s----gigabyte z97x-sli----8gb ddr3----gigabyte g1 gaming 960----HAF 912----120gb ssd----1tb hdd----500w evga----
32 bit also has a limit to the amount of ram you can use afaik. Depending on what the machine is used for, for example lets say gaming, I would recommend 8GB of ram or more. 32 bit only supports 4 I think.... 2^32 so yeah.
I thought encryption and some programs benefited from 64-bit.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
If they're 64-bit software they will. But 64-bit software won't run on a 32-bit OS at all, so there's no point in comparing the "speed difference". It'll run on one, it won't run on the other. Simple as that.
I thought it made some sort of performance difference because a few years back, I was playing Minecraft on this average laptop, but I had 32-Bit Java. I decided to uninstall the 32-Bit and install the 64-bit Java and it made a huge difference, it went from like 23-35fps to around 60.
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
http://www.anandtech.com/show/1164/17
It's the same program isn't it ? and they just recompiled it so there is a point at comparing the speed.
  ﷲ   Muslim Member  ﷲ
well if it was running on 32 bit it would decrease its available ram so that's the only difference.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
That laptop only had 4gb of ram to begin with anyway and I'm pretty sure Minecraft doesn't use more than 2.5GB lol
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
And this is why I am keeping my phone with a snapdragon 805 until it dies or another 3-4 years.
Then it's the placibo effect, or something less obvious.
LIKE.... THE APU!
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
Oh yea, I never used integrated graphics, almost forgot that they exist.
k, well the laptop has 4gb ram, nvidia gt540m and when I switched over to the 64 bit java, there DEFINATELY was a big performance increase (like i said from 35 to around 60 fps) not placebo
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
