Hello, I used to get good fps in for example borderlands 2 (about 60fps) But now I get only 12-18fps. I know my pc can handle it because it used to handle it properly but now it lags. My gpu is Nvidia 970, The Asus Strix if it makes any difference. I don´t know if it´s a driver problem or what. And my temps are fine. If anyone knows a solution to this problem I´d be happy to hear it.
Thanks!
https://linustechtips.com/topic/389601-please-help-asap/
do you have an intel CPU? are you running the monitor of the motherboard or gpu
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/389601-please-help-asap/#findComment-5260373
what is your GPU usage at idle
https://linustechtips.com/topic/389601-please-help-asap/#findComment-5260387
what CPU?
OP has the 4690K
https://linustechtips.com/topic/389601-please-help-asap/#findComment-5260397
Yeah I have the 4690k, how did you know?
I checked your profile, you have your system build there.
What is running in the background more?
https://linustechtips.com/topic/389601-please-help-asap/#findComment-5260525
Ok, I have chrome running in the background, but I only use about 4gb´s of ram of the 8 I have. And I used to run it at 60fps wiith like 20 chrome tabs open no problem.
https://linustechtips.com/topic/389601-please-help-asap/#findComment-5260548
