Sapphire Radeon DUAL-X R9 270X
Solved by itachipirate,
Sapphire Radeon R9 280 Dual-X OC WITH BOOST 3GB DDR5 384-bit This one is the good one,yes? This is the 280 you talk about?
Yes that's a really good graphics card. I don't think the CPU will bottleneck it too too badly, but it might a little. Don't worry too much about that though it's a great graphcis card
Featured Topics
OishiYasai ·
Posted in Displays0 -
invalid-user ·
Posted in Troubleshooting1 -
NukoTi ·
Bear_99 ·
Posted in New Builds and Planning3 -
2
1
7
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
