cleaning razer blackwidow chroma
By
Padorkous
in Peripherals
in Peripherals
Solved by GlassBomb,
To give it a proper cleaning, then you want to take off all the keys (use a keycap puller!), you can rinse the caps with water. Just make sure that they are nice and dry before you put them back on.
Featured Topics
maka0 ·
Posted in Storage Devices2 -
3
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning2 -
Xrniu ·
Posted in New Builds and Planning3 -
8
3
