hello,
What's the best choice to cool down fx 9590 cpu (as much as possible ) thinking about noctua nh-d15 ( because i love air cooling more than hydro ;)), any advice?? maybe i need water cooling like h110gt or smt??
thanks
Please don't buy a 9590 if you haven't already.  It's just an overpriced 8350.  An i5 would be a better choice.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5089779
Please don't buy it. If you did, then..... sucks 4 u.
The very most minimum I would recommend cooling the crap thing is a Noctua NH-D14.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5089796
Do you actually have a 9590?
If you haven't bought it yet, don't.
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5089799
I hope you haven't bought it already.
It will overheat and shut down with air cooling, you need a water cooler
FX-9590 runs too damn hot, should use water cooler to make it work "Nice".
If you haven't bought it then you can go with FX-8350 or i5-4460 - i5-4690K instead.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5089805
hello,
thanks
If you gotten that CPU YOU WILL NEED A WATER COOLER. If not DON'T GET IT, get one of the other FX 8XXX series. The 9XXX series are horrible and overheat.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5089858
unfortunately i already bought it.  well at least i got it on blitz sale for very cheap
Go with water cooler, there should be water cooler inside the box.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5089865
no, where was no water cooler inside the box just cpu.
What's your budget for the cooler?
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5089917
up to 300$
You can go with NZXT Kraken X61.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5090003
ok thanks a lot
Or Corsair H100i, it's cheaper and performs good. But Kraken X61 is better than H100i.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5090026
well i paid only $129.49 for it , so i gues i need to forget that money and live on with my old cpu
That is a very good price to pay for the CPU alone,problem is, you will need to also invest into a mega high end motherboard that supports the FX9, as well as $100 in aftermarket cooling. Then energy consumption per year is going to be really high with the FX9. In all honesty, just sell the CPU on eBay or craigslist as brand new for $150-$180, make a quick buck and invest into a better platform.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5090125
It doesn't actually run that hot, AMD cpu's have much lower operating temperatures than intel.
It does however put out more heat & use more power.
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5090168
If good cooler is used then yeah it's cool, also the max temperature is lower....
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5090175
hello,
thanks
an nhd 15 will be perfectly fine. the stock cooler for this chip is only a 120mm aio and the nh d15 is much better.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/376407-fx-9590-cooling/#findComment-5090263
