GTX 960 - Manufacturer Difference
Solved by xAcid9,
@OP
Go for Palit since it's cheaper, a friend of mine using 970 Jetstream and the cooler is pretty good.
From what I have heard the GTX 960 isn't really good for price to performance, either go AMD R9 270(x) or 280(x). Or go 970.
EDIT:
The 280 would be better than the 960, but the 270 will fall behind a little from what I found.
I would only go for the 280, though the 270 should be cheaper, by lots.
270/270x is much slower, 280/285 is slightly slower at stock clock. 280x is slightly faster.
