Remember that the hdmi cable costs 50 bucks, otherwise it will look crappy ^^
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/372845-1440p-help-me/#findComment-5044956
why do you want 1440p for xbox ?
it's 1080p / 900p anyway
I think he means league and GTA on his PC, plus his xbox too
https://linustechtips.com/topic/372845-1440p-help-me/#findComment-5045013
I agree that a 1440p monitor will not be fully utilized by an xbone, however if you insist on purchasing one this is the model I'm currently using and loving every second of it. But note that the built-in speakers are worse than useless... A separate audio solution is a must.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009626
https://linustechtips.com/topic/372845-1440p-help-me/#findComment-5045021
https://linustechtips.com/topic/372845-1440p-help-me/#findComment-5045029
