How to set a Hot-swap bay
Solved by LogicalDrm,
i've read that if i do this, then my computer will not boot from my ssd. is this correct or not?
ACHI doesn't effect that. Changing it to IDE would have some effect on some SSDs. Thats not the only setting you need. On that mobo, under Avanced -> PCH Storage Configuration. You can select how each SATA port acts. The option is under Hot Plug. Enable to port that is connected to your bay.
Featured Topics
Bob_The_Builder ·
racker24 ·
Posted in Servers, NAS, and Home Lab0 -
2
MightyNerdy9 ·
Posted in Displays1 -
1
CptCreeper99 ·
Posted in New Builds and Planning1 -
mrgerry123 ·
2
