Do you have a specific model in mind?
"Reference" 970s can only be bought here: http://www.overclockers.co.uk/showproduct.php?prodid=GX-205-OK
980s should be easy enough to find, though.
The GTX700 series have been discontinued, so stock is quite limited
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5031717
Where do you even buy reference GTX cards from?
Ifound some 970s (which ive never seen anywhere) at best buy oddly enough
00110000 00110001 00110000 00110000 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110001 00110001 00100000 00110000 00110001 00110001 00110001 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110001 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110000 00110001
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5031721
GeForce-GTX-960-Pops-Up-Online-Specs-Det
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5031734
snip
I believe I just ninja'd you with an edit to my post
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5031743
Depends on the model of card.
Best buy, Newegg, Amazon, etc... all those typically have them. (They might not have reference models for all nvidia cards, but they typically have some of them)
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5031780
Not true, best buy sells reference 970's that's where I got mine
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5031791
Rare cards since reference cards are the best at SLI due to the Blower fan and the fact Waterblocks are cheap since reference PCB is easier to manufacture waterblock fittings hence why they are usual sold out within a year if not less. IF you can find one good luck :)
Regular human bartender...Jackie Daytona.
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5031806
I saw that after I posted, I'd really only looked at that product page when it was the only place in the world to get them, but that's now changed
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5031815
Actually these are the best for sli
http://www.asus.com/us/Graphics_Cards/TURBOGTX970OC4GD5/
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5032141
So basically proves my point :P Blower fans! xD
It's cheaper getting a reference card and OCing it to that clock speed.
Anyone who bought this needs a slap unless they are obsessed with aesthetics. :D
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5032225
Not entirely. These are better than the reference because they pull air from air on both sides and the silicon is meant for that clock speed so there will be no instability problems
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5032240
Dam forgot about that part! But yeah Blowers are really good for compact SLI/CF builds, how much does this card cost compared to reference?
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5032281
Not sure but probably less because the cheapest that you can get a reference card is at best buy for $380
I think the price is around $350 for the one that I linked
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5032287
£186 for the ASUS Blower GTX 970 - http://www.amazon.co.uk/ASUS-GeForce-TURBO-GTX960-2048MB/dp/B00WHJJ86E/ref=sr_1_fkmr0_1?ie=UTF8&qid=1432333431&sr=8-1-fkmr0&keywords=asus+turbo+geforce+gtx+970
£246 for Palit Blower (Modified cooler chassis) -  http://www.amazon.co.uk/Palit-Nvidia-GeForce-Graphics-Express/dp/B00NPRH3P0/ref=sr_1_6?ie=UTF8&qid=1432333492&sr=8-6&keywords=gtx+970
Well it's new to me but well done Asus.
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5032480
Hell I could Triple SLI them! xD
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5032514
GO FOR IT, ALL THE PLOWER
(But tbh you would be better with 2 980's)
But then I need a new PSU I have a GS 750 from Corsair, I will wait to see how AMD stacks up and if it can clear TiX's performance by a nice margin I will by getting a good ol' R9 390X and maybe another down the line. If AMD clear TiX's performance and beat the 980ti then Nvidia have lost this year in performance since the can't release anything more powerful other than a Dual GPU card or a 950ti/960ti which would be pointless right now :)
https://linustechtips.com/topic/371646-reference-gtx-cards/#findComment-5035875
