Does static electricity kill computer parts?
Go to solution Solved by Godlygamer23,
Static electricity can damage and even destroy computer parts. I've moved computer parts across carpet in socks - didn't run into issues, but I could've been lucky. There's no real way to know without actually testing it.
If you're wondering how it can kill parts, it's due to the voltage. The current isn't much at all - the voltage though is extremely high. Static electricity can be on the magnitude of a few thousand volts.
It's not optimal to move a motherboard around while walking on carpet, unless she grounded herself beforehand.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
Not true. If she moves across carpet, she can generate static electricity(even things mid-air can generate static electricity). If she does, it goes to the parts she is holding.
I'll say this, every single computer I've built (two of them) has been built with my bare feet on carpet. Not to mention working on my own rig multiple times with my bare feet on carpet. Always made sure to touch the screw of the nearest outlet before starting though.
Dubs are better than subs
It's unlikely that static electricity would kill your components. Unless you go out of your way to build up a ton of static electricity, a little shock probably will, at most, only shorten the lifespan of whatever component it is.
Useful threads: Code of Conduct || Unofficial LTT Beginners Guide || Forum FAQ
CPU: Intel Core i5 4440 GPU: GTX 760 MOBO: Asrock Z97 Anniversary RAM: 8GB Adata @ 1600 Mhz Case: Define R4 SSD: Kingston V300 128 GB
HDD: 1TB Seagate Barracuda NAS: 3TB Seagate Barracudas in RAID 1 PSU: EVGA 600B (600W 80+ Bronze) Display: LG 23MP75 (1080p IPS @ 60hz)
I always end up being sloppy when I'm messing with my computer parts, like dragging my socks on the carpet and then accidentally touch the motherboard without grounding myself. Or I'm going to put the motherboard on the box and for some reason I have the box on the carpet and the motherboard falls of and slides (the edge slides) on the carpet and stuff like that, and I've never had a single part destroyed by static electricity, so either I am a lucky guy, or the other people are the unlucky guys!
But you should be fine, just be as careful as you can :)
GPU: RTX 2080 Super        Keyboard: Corsair K70 MK.2 RGB
CPU: i7-9700K        MouseLogitech G PRO Wireless
RAM: 16 GB Corsair Vengance PRO                                                         Headset: Corsair HS70 PRO Wireless
PSU: CX650F        MousepadCorsair MM500 Extended 3XL
MOBO: Asus Prime Z390-A        ControllerDualSense 5
Case: Lian Li Lancool II        CameraCanon EOS M50
Monitor: Samsung Odyssey G5        CoolingCorsair H100i Platinum
The white Rabbit        MicrophoneTrust GXT 252+
You yelled at her and she hates you?lol...
I wouldn't handle a CPU or RAM while dancing in my socks on the carpet with the wood stove blazing away...but I doubt a motherboard will be hurt by carrying it.
I have damaged RAM with static myself...I assume...It worked/I pulled it out/I put it back and it didn't work.
