I'm trying to overclock this cpu to 4.5GHz.
The AMD catalyst system did the test, and the slider was limited to 4500 MHz.
When I enable "Cpu overdrive" windows aero just refuses to run.
Running into CS:GO I get like 20-110 fps. really unstable, and laggy as old balls.
Tried with 4.1, 4.2, 4.3, 4.4 and 4.5 GHz. As soon as the overdrive is enabled, it's totally unplayable.
Any ideas?
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/364062-cooling-amd-fx-8350-overclocking/
that is definitely something wrong with the software.
You should Always overclock via BIOS.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
The AMD catalyst system did the test, and the slider was limited to 4500 GHz.
Any ideas?
Overclock by hand and don't use Catalyst for that.
Also what cpu cooler do you use and did you monitor the temps?
4500 GHz.
LIAR!
Temps are low. No problems there. Asus Silent Knight II.
I'll try through the bios then.
LIAR!
Haha :P
I went into the Asus Saberooth 990FX bios, couldn't figure out at ALL how to overclock it. Some voltages, but no frequency directly, which I could just put at 4500 MHz :-P Such a noob....
Knowing Asus there's probably a dedicated section somewhere. I'll see what I can find unless there's a ninja somewhere.
Go into advanced mode and it's under AI Tweaker
I'll just try this.
Okay, I overclocked the CPU to 4.5GHz.
NO noticable difference at all. Max 5 fps, in games where it was already running at like 55-60 fps.
Guess that's it for me :-D Back to 4GHz. Not worth it to push the chip, if it's gonna last me the newst 2-5 years anyway.
Terve!
I suggest you check the loads on the cores and the GPU first.
What does an overclocked CPU give you, if your poor old HD 5450 can't keep up with it?
What kind of GPU do you use?
Sayonara!
Terve!
Sayonara!
I use Radeon HD 6990. So no problem there. - GPU usage 70-90% on each
