[HTML] A bit of web design help....
Solved by Tedster,
This is probably the simplest thing to do, but I cannot figure out how. Inside of an <ol> tag, when it is centered, the numbers stay at the left. How would I get those to move over with the words?
^That is what I am talking about. Any advice?
Really simple solution: Have it not centered and do some really ghetto spacing to get it all lined up.
Take a look here:
From: http://stackoverflow.com/questions/19364836/how-to-center-ordered-list-number-in-html
You are aligning texts in the body.Try this:<html><body> <h4 align="center">HEADLINE</h4> <ol class="center"> <li>First Item</li> </ol> <style type="text/css"> .center { text-align: center; list-style-position:inside;}</style> </body></html>Hope this helps !
