How do i get my triple monitor setup going
Solved by Giganizer300PRO,
You could plug in 1 monitor over HDMI, one over HDMI to DP and 1 over HDMI to DVI.
Just make sure tho, which DVI you use, because you don't wanna have any loses.
That's basically it, you'll need to buy 2 adapters.
Featured Topics
Voy ·
gamingandblaming ·
Posted in Cooling0 -
4
SuperFlower ·
Posted in Displays1 -
Prehistoric ·
Posted in CPUs, Motherboards, and Memory2 -
Phenz ·
Posted in CPUs, Motherboards, and Memory1
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
