I have a particularly nasty piece of adware. I used Malwarebytes, Spybot and Superantispyware have all failed to get rid of this piece of adware! I have reset Google chrome multiple times and have scoured my files for traces but they wont go away! Help me!     Just one of the many examples: http://prntscr.com/6wvbyr
post-165243-0-65565600-1429714903_thumb.
My Build: Phoenix
Processor: Intel i7 4770k, Motherboard: Asus Z97-P RAM: Corsair Dominator Platinum 16GB GPU: MSI GTX 1050TI OC Case: Corsair ICUE 4000X, Storage: Samsung 840 EVO 120GB + 500GB + 2TB HDD PSU: Corsair RM750, Cooling: Corsair H100i Capellix,
        If you want to talk to me or give me an answer, please tag me otherwise you'll be talking to thin air ❤️
https://linustechtips.com/topic/353028-help-me/
-SNIP-
Well, as you said yourself it is not ads by the site itself.
Have you gone into Control Panel and looked in the programs? (As in the remove programs place)
Possibly it's their.
And you only seemed to have used malware and spyware removers. Can you try using a virus scanner? Avast or AVG or something? Maybe those will pick it up.
https://linustechtips.com/topic/353028-help-me/#findComment-4798243
That's karma for denying LMG money.
Try different browser.
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/353028-help-me/#findComment-4798250
i don't see why people would help you to not support LMG...
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/353028-help-me/#findComment-4798262
Uninstall TremendousCoupon from Windows
Remove “Ads by TremendousCoupon” adware with AdwCleaner
Remove “Ads by TremendousCoupon” virus with Malwarebytes Anti-Malware Free
Double-check for the “Ads by TremendousCoupon” malware with HitmanPro
Reset Internet Explorer, Firefox or Google Chrome settings to remove “TremendousCoupon” Ads
https://linustechtips.com/topic/353028-help-me/#findComment-4798703
