So can anyone help me with a Powerpoint question?
Solved by Guest,
Okay, so since I can't check at this very moment, this will preserve the font no matter what computer (regardless whether or not the font is installed on it) runs it, right?
I believe so, yes. I'd check for you but don't have another system with PowerPoint other than mine.
EDIT: Just removed the custom font and then re-opened the PP; seems it will only be a read-only if you want to use the font...
Featured Topics
Voy ·
Posted in Programs, Apps and Websites1 -
gamingandblaming ·
Posted in Cooling2 -
4
SuperFlower ·
Posted in Displays1 -
Prehistoric ·
Posted in CPUs, Motherboards, and Memory2
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
