clean the crap with ccleaner, uninstall programs you havent used in the past month, and disable unnecessary startup programs
https://linustechtips.com/topic/352107-how-to-speed-up-computer/#findComment-4786923
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/352107-how-to-speed-up-computer/#findComment-4786974
END OF LINE
https://linustechtips.com/topic/352107-how-to-speed-up-computer/#findComment-4786999
Racing stripes and RGB LEDs seem to work best for @LinusTech and the crew. I'd try those first.
In reality though, try clearing some start-up processes in msconfig. That should help a ton if you've never done it. Clearing out some of the crud (junk/trash/temp files, invalid/erroneous registry entries, etc.) could also help too. I use iolo System Mechanic for that. Works well, but I couldn't honestly see paying for it (got it through work via an incentive program). CCleaner looks to do much of the same as iolo does.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/352107-how-to-speed-up-computer/#findComment-4787026
Usually, cleaning out the dust from your case and components will help with lag if things are really gunked up in there - it will stop the system from thermal throttling so soon. Also, make sure that you have adequate airflow in there,
As for lag when you are not using any intense programs, defragment your hard drive, and clean out all of the unnecessary files in your system (As everyone else said).
Finally, an SSD will speed everything up.
._.
AMD A8-5500•••ASUS GTX 660•••MSI MS-7778 Mobo•••2x4GB DDR3 RAM•••CoolerMaster v550 Semi-Modular PSU•••1.5TB HDD•256GB Samsung 850 Evo SSD•••Optical Drive•••Phanteks Enthoo Pro
https://linustechtips.com/topic/352107-how-to-speed-up-computer/#findComment-4787074
