Do you already have this CX750M PSU?
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/350999-do-i-have-enough-power/#findComment-4773438
It's overkill. A decent 550w would already be plenty for either.
500B1 for 970: http://uk.pcpartpicker.com/part/evga-power-supply-100b10500kr
or 600B1 for 290: http://uk.pcpartpicker.com/part/evga-power-supply-100b10600kr
https://linustechtips.com/topic/350999-do-i-have-enough-power/#findComment-4774609
  • 4 weeks later...
i have a cx 600 is that enough?
https://linustechtips.com/topic/350999-do-i-have-enough-power/#findComment-4949086
Keep the 600
https://linustechtips.com/topic/350999-do-i-have-enough-power/#findComment-4949094
Yes.
https://linustechtips.com/topic/350999-do-i-have-enough-power/#findComment-4949577
http://uk.pcpartpicker.com/p/q9rXBmthats all the parts would it be fine with all that?
Still fine
https://linustechtips.com/topic/350999-do-i-have-enough-power/#findComment-4950114
what about if i have 16gb of ram and a gtx 970 and 3 fans?
Yes.
https://linustechtips.com/topic/350999-do-i-have-enough-power/#findComment-4952903
