New case fan? need advice
Solved by slightlyjaded,
ok im looking at the pricing of fans an noctua industrials seem good but one thing im conserned about is that 29 db noise when the corsairs ones have 26,4 db so im asking are the noctua fans really loud i live in a apartment and i really would not want to wake up my neighbours whit loud computer
not so much. When noctua quotes 29DBa they actually mean it when it's spinning at a fairly decentish speed. Corsair has been known to fudge it's results, or quote minimum speeds. BTW 40 Dba is a whisper.
Most of the noise generated by noctua fans is from the air being moved itself, if you don't need as much air moved, then turn them down.
