Hi,
I want to build a pc for a friend and he only wants to game on it.
Whats better the Athlon X4 860K or the Pentium G3258.
He wants to play GTA 5, BF4, Gmod, Portal,... on 1080P high
And the GPU is a GTX 960
Any suggestions are welcome! ;)
Trust Me, I'm an "Engineer"
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/
I3. Get an i3 for an entry level gaming rig. Tons of performance, reasonable cost, can play any game on the market, upgrade path to i5/i7.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4683241
That Athlon will fall apart.
G3258 with a 960 should run GTA nicely
in those games single core performance wont really matter and while the g3258 is great i compared mine with a an fx4300 (the athlon but with l3 cache) and the fx beat it in games like battlefield it had lower cpu usage and didnt bottleneck wheras the g3258 was at its limits, its only redeeming features is its upgrade path which WILL be needed, so effectively its a cpu if you plan to upgrade shortly after (which is what im doing, go figure).
op needs an i3 at the least, preferably a 4440 (4460 is a waste of money)
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4683258
Here in Belgium a 4460 is 30 dollars cheaper than a 4440
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4683263
AMD Rig - (Upgraded): FX 8320 @ 4.8 Ghz, Corsair H100i GTX, ROG Crosshair V Formula, Ghz, 16 GB 1866 Mhz Ram, Msi R9 280x Gaming 3G @ 1150 Mhz, Samsung 850 Evo 250 GB, Win 10 Home
(My first Intel + Nvidia experience  - recently bought ) : MSI GT72S Dominator Pro G ( i7 6820HK, 16 GB RAM, 980M SLI, GSync, 1080p , 2x128 GB SSD + 1TB HDD... FeelsGoodMan
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4683346
i was generalizing but in those cases, sweet! here in the uk an fx8 is half the price of an i5k
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4683457
it goes like this in terms of modern gaming capabilities, so figure your budget OP and pick cheap compatible motherboards for each and compare the price (i highly suggest a good 6+2 power phase board and at least a 30$ aftermarket CPU cooler for the FX-6300 and FX-8320 making them more expensive)
Pentium G3258 ---> overall the weakest  in modern games.
Athlon 860K ---> SLow as hell too but at least it can play all the games without you having to fuck up with the game to get it to launch and then it's 30FPS constant instead of like the G3258 where it's 85FPS at times with drops in the 17FPS range and 2 second long stutters occuring every 8 seconds of gameplay...it's slow but it's constant and more even...therefore more enjoyable IMHO.
FX-6300 ---> this in most cases is slower than the core i3-4150, require a ton of power and heat dissipation to overclock and get reasonable performance, that's why it's lower.
Core i3-4150 ---> Now you get in the relm of the CPU's that can play any modern games relatively well, a good match for a mid-range card such as the R9 280 or GTX 960 for 1080p gaming for example, you'll get 45 to 60FPS out of such a setup in DEMANDING games)
FX-8320 ---> i rank this one above the Core i3 for performance, indeed that CPU once overclocked will run most MODERN AAA TITLES better than the core i3 chip IMHO, after testing both i've found the FX to have more ''guts'' in multi-threaded modern games BUT it fall short in single-threaded MMO's, RTS and RPG's if that's something you're into get an i3. The FX-8320 also consume A TON more power than the little core i3 and need a more epensive motherboard and good after market CPU cooling solution, this one once overclocked will heat up your room pretty fast...the socket is also dead and for a setup that would cost you as much i aint recommend this processor...i didnt like mine.)
Core i5-4440/4460: ---> THIS IS THE SWEETSPOT, that's where you want to be...this one can play any GPU maxed out at 1080p in most games and is a strong quad-core chip and that's what you want for gaming.
I could keep going but clearly we must have capped your budget at this point!
IMHO you should save for a core i3-4150 and a cheap H97 motherboard at the very least for your GTX 960
A core i5-4440 and a cheap H81 motherboard, and a single 8GB DDR3 RAM stick might be a good option as well.
Good luck!
EDIT: With the prices right now if you are in the US this is the king for performance/dollar in modern AAA titles IMHO:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory  ($49.99 @ Newegg)
Total: $267.93
Generated by PCPartPicker 2015-04-08 07:42 EDT-0400
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4683838
Good luck!
Total: $267.93
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4700199
So if i Pick a FX6300 and a aftermarket cooler wil that be good For doing multiple things at once i am more on to Intel anyway
nop nop mop
stick to I_build_nanosuits advice
get i5
if not the i3 is a good CPU too
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4700942
No because you also need a decent motherboard for overclocking FX-6300 and with the aftermarket cooler it will end up costing about the same as the intel i5-4440 kit i've linked above ^^
If this one is too expensive then drop the CPU to a core i3, it will still be better all rounder than the FX-6300.
This is the cheapest way to overclock the FX-6300 and match the core i3 in (some) games:
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($94.88 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.98 @ NCIX US)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($78.99 @ SuperBiiz)
Total: $202.85
Generated by PCPartPicker 2015-04-10 07:42 EDT-0400
That's it, you can't go with a cheaper motherboard than this one which is an 8 phase motherboard that is good for overclocking and you need at least one of these hyper 212 cooler in order to overclock...as you can see this kit is only 60$ cheaper than the i5 kit.
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4701357
If he doesn't plan to upgrade anytime soon, I'd suggest the Athlon, since it's quad core, and dual cores will start struggling soon with AAA titles (Far Cry 4 for example). If he is upgrading soon (within about a year), get the Pentium, it'll be good for now, but when only having a dual core becomes an issue, he can get an i3 or i5 without swapping motherboards.
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4702277
Hi,
do you have a budget? if you want to play GTA5 then you need something more powerful than a G series or Athlon.
its worth saving an extra $100 can go a long way and go for an i5 or 6/8 core AMD rig as min,
got to love Asus components
https://linustechtips.com/topic/343778-cpu-for-a-gaming-build/#findComment-4703536
