Ziftrcoin not mining (GTX 970)
Solved by Sentiago,
I see this http://prntscr.com/6q5p9vcan i get some help!? Thanks!
It says This can't start because cudart32_65.dll is missing... What's that?
create a .bat file with the following code, inside your Ziftrcoin directory:
ccminer -o stratum+tcp://ziftrpool.io:3032 -u REPLACE THIS WITH YOUR USERNAME -p x -a zr5If you get the cudart32_65.dll is missing error, use Chippas64's link, and place the .dll inside your Ziftrcoin directory.
Announcements
Featured Topics
ShadowSweaty ·
Posted in Troubleshooting2 -
s1eroo ·
Posted in Graphics Cards2 -
CosmicEmotion ·
Posted in Windows4 -
ki8aras ·
Timiii ·
Posted in Graphics Cards3 -
22
jordanbuilds1 ·
Posted in General Discussion5 -
9
11
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
