"Bookshelf" speakers with punch + an amp for them
flibberdipper
So no matter where I ask the question for a cheap amp for my current speakers, the answer is always the same: Cough up some dough or you're SOL.
Which leads me to my new question: What are some cheap "bookshelf" speakers (like speakers that are 12" tall and 6" wide, so on and so forth) that have good punch (I am all about that bass, trust me), as well as an amp to power them both? Audio will be coming from my PC. I already have 50 feet bundles of wire to place them wherever (from my current speakers). If the price could stay under $150USD max, that would be wonderful. I don't really care what the speakers look like (although I do look the natural wood look of my NS-A600's), and they don't really have to have speaker guards/mesh since they'll be on my desk.
TL;DR: Read the damned post.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
@Enderman - Speaker Expert
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
Check /r/averagejoeaudiophile
Something tells me /r/budgetaudiophile might be better. Now, what the fuck was my reddit info...
Main rig on profile
VAULT - File Server
There's nothing wrong with the Lepai amp, youay want to upgrade the power supply on it though. As for cheap bookshelf speakers with bass, Micca MB42x's are probably what you are looking for. You can add a dedicated subwoofer later for some more punch.
Internets Machine: Intel 4690k w/ Be Quiet! Pure Rock 4.7Ghz. MSI Krait z97. 16GB Crucial Ballistix Sport Ram. MSI GTX 970 SLI 1520mhz. 500GB Samsung EVO 840  & 3TB WD Blue Drive. Rosewill 1000w Modular PSU. Corsair Air 540
My Beats Yo: Desktop:SMSL SA-160 Amp, KEF Q100 w/ Dayton 100w Sub Theater: Micca MB42X-C x3, MB42X x2, COVO-S x2 w/Dayton 120w Sub Headphones:  HIFiMan HE-400i, PSB M4U2, Philips Fidelio X2, Modded Fostex T50RP, ATH-M50, NVX XPT100, Phillips SHP9500, Pioneer SE-A1000, Hyper X Cloud 1&2, CHC Silverado, Superlux 668B
I don't think I would want to ever think about running two speakers rated at 140w/8ohm on an amp that's rated for like 20 watts. :P
Anyways, those ones are expensive, what about the non-x version? What makes the x version better than non-x?
And finally, what sub would you recommend? Maybe like... $70 for that at the most, and it NEEDS an adjustable knob to turn its effect up or down (this stuff would be at my grandma's, so you can see why I need that feature).
Main rig on profile
VAULT - File Server
I recommend getting an amp used on craigslist.
The world is full of stupid people selling 300$ amps for 50$, with speakers
Nothing wrong with that. The speaker can (theoretically) handle 140W, and the amp puts out 20W. Works perfectly fine.
There's nothing wrong with that, as @Lutkeveld said
My Micca MB42's off my Lepai amp get STUPID loud.
What the difference between the MB42's and the MB42X's? I couldn't find anything...
Main rig on profile
VAULT - File Server
The x means that it has a crossover, which basically means that it is better at spreading out the frequencies to the proper area (tweeter, speaker, and sub). The cheapest sub I could recommend is $80 which it is the Dayton 80w sub
This guy does a good job of explaining stuff, and also has a very good review of the mb42's and X's I think too.
I am glad I am not the only LTT member that likes Zeos.
craigslist is the best place to get good speakers for your money
i dont know which bookshelf speakers are best since I dont use those, but I can tell you that there are tons of people on craigslist selling great quality bookshelf speakers and amps for extremely cheap
also its not a complex electronic device like a GPU, so buying it used (if its in good condition and works) is no different from buying it new
Besides rotten surrounds and dried up electrolytics. But generally yeah; old stuff is still good.
thats what i meant by good condition :)
newer speakers that use rubber or synthetic surrounds are much less likely to fall apart over time like the old foam surrounds used to
