Quietest configuration for case
Solved by blackadder,
i don't recommend that. You need airflow. Don't close off your front intakes. It won't be that loud, this depends of you. You want a intake and a exhaust to be a free flowing as possible, it makes more aiflow and less noise. 2 or 3 great fans can makes temps cool and noise not be a problem for most people.Now remember that my only intake would be the fans pulling air from the radiator into the case. I was thinking that a cooler without the rad would allow for cooler/slower fans.
