Thermal paste question
Go to solution Solved by ANewFace,
It's a fine thermal paste, and good brands are Arctic silver, and IC Diamond, but stock is fine.
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/339700-thermal-paste-question/#findComment-4630978
If you are using the stock cooler I'm guessing you aren't OC'ing and so that would mean yes the stock cooler's thermal compound is fine. You can see up to 7 degrees different if you change it to a different thermal compound but it isn't necessary.
https://linustechtips.com/topic/339700-thermal-paste-question/#findComment-4630986
Well I have two.
I have a 4790k. Is the thermal paste on the stock cooler good enough or should I remove it and use something different?
Also what are some of the better brands to use?
Intels stock coolers are not really good. It's okay for not too heavy stuff and no OC.
For thermal paste: getting Noctua, Arctic Silver, IC Diamond... will work well.
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/339700-thermal-paste-question/#findComment-4631052
@SocomSuade, don't forget to follow your topics!
https://linustechtips.com/topic/339700-thermal-paste-question/#findComment-4631067
Well I have two.
If you are using a stock cooler, than you must be using the CPU at stock frequencies, intel has validated this cooler with this CPU to work, they wouldn't include if it didn't meet certain requirements.
Now obviously a after market cooler like a 212 evo would give better temps, you shouldn't be worrying about the thermal paste, as much as the cooler it's self.
https://linustechtips.com/topic/339700-thermal-paste-question/#findComment-4631075
Ok thanks all.
Not Going to OC just yet. When I feel brave enough I will buy aftermarket cooler.
For now just a lot of gaming andsomr browsing/youtube.
I'll stick with stock paste for now and reapply with better paste and better cooler when ready to OC.
https://linustechtips.com/topic/339700-thermal-paste-question/#findComment-4631226
