how to clean solid thermal paste
Go to solution Solved by givingtnt,
credit card and scalp it off
I can't wipe it off GPU cooler, it's rock solid
https://linustechtips.com/topic/336457-how-to-clean-solid-thermal-paste/
Got any isopropyl alcohol? That'd do it.
Yeah, and it didn't do it
Keep the alcohol on it, it will start to melt.
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
soak it in alcohol
keep saturating the dried up paste & make sure you rub it in a circular pattern until it starts to give in , it'll take time & could use up a bit of isoprop to get it done but make sure you dont make a bigger mess of things & use a tisse or cloth with heavy texture to it , that can help you as well, if all else fail use a heat gun on low settings as you clean it, might help...
Details separate people.
