No flame war please.
All the shit posts today...
Anyway, between those two if you're just buying the cpu with no gpu at all the A10 wins, its graphics cores are far superior to anything intel has, if you're buying a stand alone gpu, then the 4590 wins, far stronger cpu cores than the A10
Oh and a tip. If you don't want people to HATE you on the forums, or get your threads deleted/locked try not naming it something so, *Volatile*
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509908
-snip-
the i5 is better for gaming with a dedicated GPU, since the AMD CPU is meant to be an APU (and with the i5 you actually have an upgrade path)
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509913
 which brand processor is best ?
like
AMD Kaveri A10-7700K APU With Radeon™ R7 Graphics
        VS
                   Intel 4590 3.3GHz Core i5
the i5. but the title is misleading lol. could cause a lot of flame wars.
the i5 has a better single core performance thjan the apu. but afaik, the integrated graphics on the apu is better than the i5's
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509915
AMD as far as price to performance.
Intel as no-questions better performance.
/thread
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509916
Did you even read the post? He asked which CPU was 'better' (which should have been explained better..) and just titled it..
Maybe a little too provocative
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509921
oh boy here we go again.......
ok go for thje i5 if you will buy a separate gpu
if you are only gonna run the cpu without a descrete gpu then go for the a10
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509923
Use Anantech CPU bench to get comparisons. Compare MANY different CPU's in various programs.
Even if yours are not listed, there are the ones above and below a single step which you can collaborate your answers from..
http://www.anandtech.com/bench/product/1200?vs=1198
It's PER-CORE performance which matters the most.
So when a program does NOT use all cores, you'd want each core to be the fastest possible.
Intel Wins in that regard for performance per core, and gaming results are better on Intel than AMD.
When maxing out details and your GPU bound (100% GPU usage) then you won't see much difference.
In CPU heavier titles, there may be more of a difference for sure... esp 'Minimum framerates' which is the MOST important for visual smoothness.
If your chasing up to 60fps, either will no doubt be fine for most tasks...
As stated, Intel with a seperate GPU, is the clear winner.
If your using the onboard graphics, the 7700K is the winner...
TBH - I'd go Intel and still put a cheap GPU in place until you got a faster GPU.
/All these responses of 'i5 ftw' and no reasons from these people why THEY would choose it.
Which would help the OP understand more.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509936
I did, which is why i then edited my post less than a minute afterwards.
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509940
Sounds like one of those guys who immediatly post "Reserved" on a popular post (like new LTT videos)..
Kinda weird stuff man..
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4509970
Not saying you use these OP but...instead of the google search's CPUBOSS and GPUBOSS, there is a better comparison site..
Even if yours are not listed, there are the ones above and below the model which you can collaborate your answers from..
/All these responses of 'i5' and hardly any reasons from these people why THEY would choose it.
Which would help the OP understand more. The more people answer the more info he has,.. as long as people go into some actual details.
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4510045
Eh, i tend to find myself editing posts i mate a LOT after i post em. like, i edited that post like 5 times after i posted it. Anyway yea, i will admit this, I read the title, and the first sentence saying "which brand has the better processor"  and just posted that out of spite. then after reading for 5 seconds longer i realized he had a legitimate question behind the horrible thread title and opening sentence; so I edited my post to make it relevant.
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4510046
I re-edit my posts after making them,... within reason, so do MANY of the users here (they've admitted it too)
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4510065
I edit my posts. Usually it's to add on, or to correct something minor. Completely changing only happens in certain situations.
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4510078
I meant to add on also, I never completely change it., although I may reword some of it also.
Anyway ONtopic - OP - Many posts already you can read,.. most of us are probably awaiting your next post before adding more.
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4510082
At least I didn't completely change it. Only added more onto it to make it relevant.
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4510084
And that's what a lot of us do. Some don't, but.
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4510090
i have
r9 270x
But fot this do i need to buy another psu ?
https://linustechtips.com/topic/332274-need-a-cpu/#findComment-4513914
