Couldn't find a suitable section for this.
So, cans of compressed air are fairly expensive, so I think I'd rather just get an air compressor for multiple use.
I would just like to know what sort of PSI I should be looking for. I want to get the dust off, but I don't want to blow the capacitors off my mobo. Any ideas?
Thanks,
Seraphim
https://linustechtips.com/topic/328839-pc-cleaning/
Instead use a brush and paper towels and water.Make life much easier
9590|EK-Copper|Sabertooth 990FXR2.0|16GB RIPJAWS Z|Dual MSI Gaming 290|Corsiar AX1200i|Corsair 760T|3TB Seagate+Dual 120GB Samsung 850EVO in Raid 0
LTT'S Official Radeon Master Race Club Founder-Predicts TitanX2 (Prediction Date: 3-30-15)
XFX Needs To Make A 3 Fan Cooler
https://linustechtips.com/topic/328839-pc-cleaning/#findComment-4463701
Use a bike pump with a small nozzle
Does the same as a can of compressed air or an air compressor
https://linustechtips.com/topic/328839-pc-cleaning/#findComment-4463709
500w fucking vacuum?!?PEOPLE DON'T HAVE $60 TO SPEND ON A VACCUM AND THEN GET A CORSAIR CX500w POWER SUPPLY!
https://linustechtips.com/topic/328839-pc-cleaning/#findComment-4463735
Considering OP is looking for an air compressor its around the price range. It also plugs into the wall... It pays for itself within 8-12 cans of air. Go shit post elsewhere.
https://linustechtips.com/topic/328839-pc-cleaning/#findComment-4463747
For me, a can of compressed air is worth it.  It lasts longer than you'd think if you're conservative with the air.  A compressor may be a bit expensive especially for the number of times you'll actually use it.  But I don't know the prices of air compressors and compressed air in your area.
https://linustechtips.com/topic/328839-pc-cleaning/#findComment-4463756
I know of refillable cans of air. but I defiantly do not reccomend using a air compressor itself. It creates tons of static.
Is it bad that my dream setup only costs a few thousand not counting the obutto?
CPU: FX-8320
Motherboard: asrock 970Pro3 r2.0
Memory: Team Zeus Blue 8GB DDR3-1600 Memory
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card
Case: Deepcool TESSERACT BF ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Certified ATX Power Supply
SSD: MX100 128GB
HDD: WD 2TB black edition
https://linustechtips.com/topic/328839-pc-cleaning/#findComment-4463773
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/328839-pc-cleaning/#findComment-4465937
Thank you all for the overwhelming responses! I hadn't heard of the Metro Electric Duster, but I think I'll definitely investigate this. It seems a few people think it's a good idea, and canned air is £15 ($20) where I live, so it'll pay for itself in no time!
Thanks for your help as always,
Seraphim
https://linustechtips.com/topic/328839-pc-cleaning/#findComment-4470426
