Will I need fans? If so, what fans are relatively silent?
Case: Fractal Design R5
CPU: Intel Core i5 2320
CPU Cooler: Noctua NH-D15 no fans
Power Supply: SS-520watt Fanless
SSD: Crucial MX100 512 Gigabyte
Graphics Card: GT 630 With Arctic Accelero S1 Silent Passive Cooling VGA Cooler
Motherboard: P8H61 Micro ATX Motherboard
Ram: 4GB Patriot Ram
Optical Drive: Asus DRW-24B1ST
https://linustechtips.com/topic/328648-silent-build/
what colour for the fans
https://linustechtips.com/topic/328648-silent-build/#findComment-4461046
Why not just get a new i5 and ditch the graphics card?
That card+cooler is an extreme waste of money
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
https://linustechtips.com/topic/328648-silent-build/#findComment-4461170
I'm guessing your use is for some gaming?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($99.99 @ Newegg)
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card  ($549.99 @ SuperBiiz)
Case: be quiet! Silent Base 800 ATX Mid Tower Case  ($119.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $1582.59
Generated by PCPartPicker 2015-03-15 12:39 EDT-0400
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/328648-silent-build/#findComment-4461238
Now this is a silent build to behold! My PC is also silent optimized, but nowhere near as this.
IMO you shouldn't get fans first because you don't want to hear anything coming out of your PC, which I totally understand.
However if it's getting warmer inside than it should, get a few Be quiet fans immediately, and also consider putting one on the CPU cooler, that makes a big difference and you will barely hear Be quiet!
https://linustechtips.com/topic/328648-silent-build/#findComment-4477813
Hello,
Are you buying this new or is this your existing PC? If you already have that PC, you are on a great way to achieve silence! Especially because you don't include a HDD.  :) Some bequiet silent wings 2 140 mm or noctua NF A14 would to niceley.
If you're buying new, then yes, you should choose some more up to date parts, especially for the GPU, but you're on the right way. ;)
who cares...
https://linustechtips.com/topic/328648-silent-build/#findComment-4477864
