Hey,
I installed some new fans for my radiator today, and I had to remove my graphics card to get some space for my screwdriver. I plugged it back in once I was done, and after some hours of playing CS:GO, I suddenly get this VERY loud coil whine. I'm sure it's from my grapics card, because if I close the game, it stops - if I open it, it starts immediately.
I know coil whine's are pretty common nowadays, but can it be my fault? Power connector wrong way etc? I have never had this problem before, and was so happy with it. It seriously sounds like it's going to blow up.  :lol:
Graphics card: Strix GTX 970
Processor: Intel i7-4790K *4,8GHz  Graphics card: MSI GTX 980Ti  Motherboard: ASUS Maximus Vii Hero RAM: Kingston HyperX 16gb PSU: Evga SuperNova G2 750W Cooling: Corsair H100i Storage: Samsung 840 EVO 250gb SSD & Seagate Barracuda 1TB Chassis: Corsair 750D Monitor: ASUS Rog Swift PG278Q
https://linustechtips.com/topic/327635-sudden-coil-whine/
I had some coil whine from my PSU, but now it's the graphics card. I doubt it's too much power usage, I have an EVGA 750W G2 (Gold 80+) - hope I got that correct.
Intel i7-4790K @ 4,8GHz
GTX 970
These are the main factors that uses most of the power, and I'm thinking it isn't even near 750W?
https://linustechtips.com/topic/327635-sudden-coil-whine/#findComment-4449841
It's a very common complaint for the Strix card.
Intel 4790 K - R9 295X2 - Gigabyte Z97-SLI - Corsair Vengeance Pro Black 1866 CAL9 - Corsair HX 1000 -Samsung 850 EVO SSD - Samsung HDD - H100I - Corsair C70 - G400 Logitech - Asus VS247H - WASD custom mechanical and QCKPAD!
Staples of LTT: Getting an 4690 K will resurrect your lost family members, AMD = More heat thus AMD = Satan.
https://linustechtips.com/topic/327635-sudden-coil-whine/#findComment-4450292
This happened to me on one of my old cards XFX 7970's  it was perfect, i took it out to do some cable management, put it back in and bam coil whine.
Its just vibrations so tbh, if you jarred something lose while moving it around, yes it could be your fault, But it happens oh well.
CPU - Intel Core i7 4770K @ 4.80GHz / GPU - MSI GTX 980 4GB Gaming / RAM - 16 GB G.Skill TridentX 2400 MHz / Motherboard - Maximus VI Formula / CPU Cooler - Kraken x60 / Power Supply - Rosewill Lightning 1300w / Case - Enthoo Luxe Monitor - Asus ROG Swift PG278Q / Sound - Razer Kraken 7.1 / Keyboard - Razer Blackwidow Chroma / Mouse - Razer Naga Hex + Razer Deathadder Chroma | Picture - [http://i.imgur.com/SSKZKWu.jpg]
https://linustechtips.com/topic/327635-sudden-coil-whine/#findComment-4450319
