Load test put bubbles in res?
Go to solution Solved by airdeano,
as coolant is heated, it expands (displacing air). the air then is pushed out into
the tubing. collects into the res (like it is supposed to). you still have air in the system.
I did a test, with my loop, passivly, got up to 50 degrees before i turned on fans, but now a bunch of bubbles apeared in my res. Is this normal?
This would be the first time my loop got above 40 degrees, and it got to 50 degrees.
(thats the CPU temp BTW)
https://linustechtips.com/topic/327594-load-test-put-bubbles-in-res/
you have the res before the pump in your loop right?
Yes, of corse.
ITs a pump res combo BTW, XSPC photon 170 with d5 pump
My guess is you have a PWM pump? If so the temp getting higher might of caused the pump to run at a higher speed and knock loose some air.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
Nope, d5 pump, always kept same speed, it has a knob at bottom to change spee, which i didnt
bubble in the res means:
air still trapped in loop
pump speed is too fast (cavitation)
has nothing to do with heating of the coolant (unless the coolant is weak or contaminated).
Well the bubbles did not appear untill the coolent was heated.
No bubbles for the past 2 weeks, i load test, and it bubbles
is this a new loop?
probably just bubbles bleeding out slowly
wait, you have a loop capable of going fan-less and staying under 60*C???? O.oo.O *jelly*
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
is this a new loop?
Not really, around 1 month old, didnt buble since first week, and now, once i load tested it
No, well maby.
I stopped at 50 degrees, as i want to make sure nothing is weird.
Ill do a reall test later today, see what it is after 30 min of prime 95.
I can tell you, load with fans, cpu stays under 40 degrees
bubbles are trapped air. and the system is sealed, so there still is air in the loop
(not easily found).
But why is it that they came out once i put it under load?
That doesnt make sence
Ok, that makes sence, thanks
usually, i'll ramp the temperatures up to do a couple of things:
cure the TIM paste, purge air from the system, test the failure of fan system.
right, i never really got it up above 40 degrees before.
I say my temps are pretty good, but now, they may be even better.
yeppers.. purging all the air out will increase the thermal capacity of the loop.
air-to-air heat exchangers are densely packed with a lot of fins, water-to-air
doesn't have to have as much fin density as the air counterparts. ideally,
you'd want a hydraulic action within the loop. 200ml coolant pulled from the
reservoir and 200ml put back into the reservoir. so when you see the reservoir
pull down from the pump pulling coolant in and nothing pushing back into the
reservoir, that is air (compressing) and blocking the coolant from returning properly.
