Doubtful.
Well if you're listening to songs on youtube for example the audio quality is absymal even if you choose the "720p" option (anything 720p and above on youtube has a 384kbps stereo bitrate for videos uploaded after winter 2014), so most songs on youtube will be 152 or 128kbps at best even on 720p.
Even something like spotify non-premium sounds loads better than the best audio you'll find on youtube even to an untrained ear like me. So yes, the source files matters a lot, especially for more expensive IEMs or headphones which are a lot less forgiving than cheap ones when it comes to a bad source.
"Common sense is not so common." -Voltaire
Fascinating, but Youtube is a worst-case scenario. For the most part, what the OP describes does not sound like an issue with file quality.
I think this depends more on the quality of the upload. Plenty of songs sound just fine at 128kbps, whether or not on YouTube.
But it makes you more audiopeel if you can hear the difference AND describe it as trash.
ya and bigger numbers too :]
EQ or be happy with what you got.  You can't make anything sound better than it already is.  If the song sounds like trash it's either the source, the encoded file, or your brain.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
I'm not even one those advocates for loss-less audio like many "audiophiles" are, I think the difference between a well encoded AAC or MP3 file and a FLAC or apple lossless file is negligble and you wouldn't even be able to tell it in a blind test.
Even though you might have some good quality tracks, we have to face that youtube is the most popular music platform in the world now and that 90% of the music you'll find on youtube sounds like utter junk.
*cough 90% of the music on youtube is pop.....
Yeah a lot of pop is poorly mastered and has next to no dynamic range.
Then again it sounds like a convoluted nonstop mess even if it is well mastered so I guess po(o)p music is a lot more forgiving for shitty headphones or shitty sources.
Maybe 90% of uploaded music, but not 90% of music I've found. Probably the opposite.
And that's even before mp3 conversion!!!
Yes that's what I meant. The quality of the songs uploaded on YouTube. Not the selection, because you can actually found some obscure hard to find tracks on YouTube that you would never find on iTunes or Spotify.
Want to try and get the experience to change?
Put the left bud in your right ear and the right bud in your left ear then turn around and face the other way.
Yeah, that's a mind fuck right there...
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
Black Sheep by Metric had the vocals sung by Brie Larson in Scott Pilgrim VS The World, and you literally can't purchase that version AFAIK because it was a pre-order exclusive for the movie's soundtrack on iTunes. As I love Metric's music, but dislike the way their lead singer sings, I must resort to YouTube.
https://youtu.be/-jMruFHTwrY
I'm no audiophile , but when I first started using Spotify ( used youtube previously ) for music , I can actually hear the difference in quality.
Also , yes changing eartips does change the sound quality.
Of course this is based on my limited experience
