Hey guys I was wondering how much FPS on games like Battlefied 4 , Far Cry 4 , ETC I would get on this rig, ALL FEEDBACK IS APPRECIATED!!
CPU: AMD FX 8350
MOBO: Asrock Mobo
RAM: Crucial 8GB DDR3 Ram
STORAGE: Seagate 1TB HDD
STORAGE: Crucial MX100 SSD 128GB
GPU: Nvidia GTX 960 2GB Overclocked
PSU: NOX 750 W PSU
CASE: NZXT Phantom 410(White)
https://linustechtips.com/topic/322414-how-well-will-this-system-do/
AMD FX 8350 Asrock Mobo Crucial 8GB DDR3 Ram Seagate 1TB HDD Crucial MX100 SSD 128GB Nvidia GTX 960 2GB Overclocked NOX 750 W PSU NZXT Phantom 410(White)
Should be medium/high settings around 70 fps in these games.
Also a 650w psu is plenty, but make sure to get a better cpu cooler.
But I would spend a bit more money and go for a i5 4440 or better, don't bother with the AMD.
For a purely gaming, nonstreaming rig, don't bother with an 8350.
Get an i5-4440 & cheap lga 1150 socketed  board and call it a day. Also, the 960 was kind of a flop from nvidia. An r9 280x is priced the same, sometimes even lower and solidly outperforms the 960.
however, other than that. The system is fine. You should be able to game w/o any issues, and stream to boot with the great multitasking capacity of the 8350.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
Good, it will handle Battlefield 4 fine. (Not sure about Far Cry because I have not played it.)
-- It is a good system, you could play most games with it on Medium/High
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
It will do a pretty decent at job at high settings at 1080p. Question is have you already ordered the parts? If not get an i5 4440 and h81 board. It would be cheaper than the 8350 + motherboard while performing much better in games. Also with the money saved you can get a better gpu like an r9 290 which is almost twice as fast as the 960.
Well my chart doesn't want to work at all. Here's a link to it instead. (Gtx 960 benchmarks)
http://www.bit-tech.net/hardware/graphics/2015/01/26/msi-geforce-gtx-960-gaming-2g-review/3
CPU: AMD FX 8350
MOBO: Asrock Mobo
PSU: NOX 750 W PSU
Go for an Intel CPU (like i5 4440) and change motherboard.
Go for a smaller PSU. 550W 80Plus gold isfine.
Evga makes some good PSU's.
GTX 960 is decent for 1080p gaming, but maybe look at the 280(x) too.
You will get 50-ish fps BF4 1080p Ultra no AA
whats the total cost?
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
i would wait until the new 4gb gtx 960 comes out and see how much that is before building this
If i where that guy the 970 is only $150 More. just fuss up the money. way better gaming experience
Thank you to EVERY ONE who has posted , This has made it much more easier. So I think i'm gona ditch the fx 8350 and go for an i5 (4440 , As this pc is only going to be used for gaming and nothing else) , change the mobo and go for an r9 290 or a GTX 970.
