How long is thermal compound considered "usable"?
Solved by AcupunctureSoup,
+1 for as long as it will flow out of the tube you should be good.
If you're ordering parts though you might as well just order another tube just order another tube since they are only like what 5 bucks?
But if your parts are already there just go ahead and use it, should be fine
They arrived today and I can't wait to start building. Thanks for the help though!
Featured Topics
maka0 ·
Posted in Storage Devices2 -
3
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning4 -
Xrniu ·
Posted in New Builds and Planning3 -
8
3
