Hey guys, i had some parts i wanted to order off of pcpartpicker.com and just wanted to run it by you guys to confirm that this is a good build for playing watchdogs (doesnt have to be at highest sets) and that parts will be compatable.
thanks!
baba
oops... http://pcpartpicker.com/p/WdfPLk
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
https://linustechtips.com/topic/318732-pc-parts-are-compatable/
thanks!
baba
Can you link them? 0.o
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333021
yeh dude all the parts you didnt link are compatible!
nice build!!!!
edit: yes its all good
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333028
well my brain sure isnt functioning correctly today... BRAIN Y U NO WORK
They are compatible. PCPartPicker tells you.
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333042
STAHP MAKING FUN OF ME
They are all compatible but I think you should save a few bucks and get a mid-range or higher-end i3 as they beat the i5 in per-core performance if that's important to you (AKA you just game and web browse).
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333049
thanks!
baba
Yes. Now stop wasting time and go buy them.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333052
so... the i5 that i am choosing not good? i thought i3 was bad!
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333059
The i5 you chose is fine. I'm just saying that you can save money if all you're going to do is game. If you're going to do multi-threaded stuff like video editing and 3D rendering then the i5 is a better choice. But per-core performance is super important in games and the i3 4370 beats the 4460 at that specific service.
And no, the i3 is in no way "bad..." Not sure where you heard that from.
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333077
Nothing's wrong with it.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333086
You are better getting 2x4GB of RAM as it's better.And an i3 would give you a much larger budget. For example: PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($104.75 @ OutletPC)
Motherboard: Asus H81M-D PLUS Micro ATX LGA1150 Motherboard  ($44.49 @ Newegg)
Memory: A-Data XPG V2 8GB (2 x 4GB) DDR3-1866 Memory  ($63.99 @ Newegg)
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card  ($159.99 @ Newegg)
Case: NZXT Source 220 ATX Mid Tower Case  ($41.99 @ Micro Center)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ OutletPC)
Total: $538.07
Generated by PCPartPicker 2015-02-27 20:23 EST-0500
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333115
Total: $538.07
Generated by PCPartPicker 2015-02-27 20:23 EST-0500my
my budget just got moved from the current price to 612$. Any additions anyone?
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333226
Add a 128 GB SSD in there... makes a big difference.
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333239
Lol you know nothing if you think the i3 is bad. It's capable of 1080p gaming easily. KNOWONE NOTICEDTHIS BUT YOUR RAM ISNT SHOWING THE PRICE. YOU HAVE A $500 build and you put a i5..... Omg. Sorry if it sounded rude xD
A better $500 build.
http://pcpartpicker.com/p/GYJjgs
Just downgrade some parts. Can't believe no one noticed that your ram wasent showing the price. Get a gtx 750 to or something
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333249
Explain why your build is better... I'm seeing more expensive parts, not necessarily better.
You're supposed to use your brain sauce and guess :P
I'm not that good!
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333272
Wait doesn't watchdogs require windows to play? I didn't see a copy of Windows on there
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4333529
well lets just say i have that all figured out... hint hint utorrent
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4348107
Don't tell people to use an illegal service to get content. Pay for your games, or they might not exist.
https://linustechtips.com/topic/318732-pc-parts-are-compatable/#findComment-4348132
