Hey guys, I was wondering if I could have some feedback on the different parts that I used in this build, and if there was anything else that is better/nicer that I could go with!
I already have:
Razer Blackwidow Chroma
Razer Deathadder Chroma
Logitech Z506 5.1Channel Speakers
Turtle Beach x12 Headset (Don't go with this, I hate it, it's so uncomfortable and isn't even good quality)
Build: http://pcpartpicker.com/user/16aswag/saved/
I wanna stay around the 1700-1800 price range, but if needed, I COULD go up to 1900 or even 2000. Thanks!
Also are there are good anti-shock wrist bands, cause I get shocked a lot, and don't wanna break my hardware...
https://linustechtips.com/topic/318442-first-build/
Link is broken, please fix it.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/318442-first-build/#findComment-4328469
Link dont work.
Remove the space behind the link, always try that when a link doesn't work
https://linustechtips.com/topic/318442-first-build/#findComment-4328491
imo this PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.75 @ OutletPC)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.99 @ Mwave)
Motherboard: MSI Z97 MPOWER MAX AC ATX LGA1150 Motherboard  ($87.99 @ Mac Mall)
Memory: A-Data XPG V2 16GB (2 x 8GB) DDR3-1866 Memory  ($110.98 @ Newegg)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive  ($158.98 @ OutletPC)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  ($279.99 @ SuperBiiz)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($149.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.79 @ OutletPC)
Monitor: Asus VX238H 23.0" Monitor  ($139.99 @ Micro Center)
Total: $1663.40
Generated by PCPartPicker 2015-02-27 09:59 EST-0500
https://linustechtips.com/topic/318442-first-build/#findComment-4328568
How is that :)
I would get this rather then yours
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($99.98 @ OutletPC)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($137.94 @ OutletPC)
Memory: A-Data XPG V2 8GB (2 x 4GB) DDR3-1866 Memory  ($63.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($118.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($569.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($17.98 @ Newegg)
Monitor: Asus VE247H 23.6" Monitor  ($137.99 @ SuperBiiz)
Total: $1805.56
Generated by PCPartPicker 2015-02-28 07:25 EST-0500
https://linustechtips.com/topic/318442-first-build/#findComment-4336103
