itll probably dry out and burn after a week
9800X3D - NH-D15S - MSI X670E  -  32GB 6000MHz CL30 - RTX 3080 FTW3 - 970evo 1TB - 980pro 1TB - 970evo 1TB - 970evo+ 2TB -  970evo+ 2TB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i -  27GR95QE-B.AEU - 28MQ780-B - 27GP850-B - 27GL850 - Meshify 2
It'd probably degrade very quickly, like mayonnaise.
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
Anything that can fill in the little imperfections on the heatspreader and the CPU-cooler will "work" as thermal paste, the problem is that other materials (like toothpaste, mayonnaise and nutella) will dry up really fast and then be useless as a thermal compound. Yes it works, but not for long.
i just saw coolermaster use nutella to as a tp :o
is that recommend coz i dont tp at the moment should i use nutella on my GPU ?
i mean it can cool an 8350 :o
I used hot glew
SHIT SHIT SHIT!
Asum.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
Guest
