Hi
I want buy and build my first PC (Click here for the specs)
I have some question about Oc'ing with my CPU.
Is the air cooler enough for (light) overclocking?
Is Mugen 4 or Coolermaster Evo 212 better?
If I do Overclocking, do I have still guarantee?
My budget is around €35 / $40 (US)
I live in the Netherlands
DutchRedGaming
https://linustechtips.com/topic/303672-cpu-cooler-i7-4790k/
it will be fine :)
https://linustechtips.com/topic/303672-cpu-cooler-i7-4790k/#findComment-4127016
I would have to disagree and say don't overclock at all with the stock cooler. I would recommend something aftermarket first.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/303672-cpu-cooler-i7-4790k/#findComment-4127027
I am able to get away with 1.275v while still having reasonable temps with the 212 evo, however, it is not the quietest cooler. It is great for small overclocks, even on a 4790k
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
https://linustechtips.com/topic/303672-cpu-cooler-i7-4790k/#findComment-4132234
