I'm going to Microcenter today, is there anything I should look for?
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/302429-going-to-microcenter/
Basically everything.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/302429-going-to-microcenter/#findComment-4109537
If you are planning a build, they have the best CPU prices and you get 40 bucks off a motherboard as well.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/302429-going-to-microcenter/#findComment-4109587
Every CPU/MB, everything else is usually meh.
G3258 + PC Mate = $100
i3 4360 and cheapest board = $145
i7 4790K + Sabertooth MK II = $490
FX 6300 + GA-78LMT-USB3 (don't recommend, VRMs throttle CPU) - $90
https://linustechtips.com/topic/302429-going-to-microcenter/#findComment-4109589
