Big Loop how much Coolant?
Solved by Skander1345,
You can do the leak test using distilled water (cheap and easy to get). Once you figure out the correct amount of liquid needed that way, drain the loop (this will serve as a first time cleaning too
) and order the coolant you want with the right quantity plus a little for maintenance.
Done!
2
4
thedood2k ·
Posted in Power Supplies2 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
